No-drill front plate options
jamarksiii
Kerrville, Texas
2023 Ford Mustang Mach E AWD w/ ext battery
I took an old LCD monitor wall mount and reconfigured the brackets a bit. The plate and brackets are heavy gauge steel, so it should hold up well. Ignore my hideous weld job! So, now I have a no cost, no-drill front license plate mount for myb2023 MME.
Ford Mustang Mach-E No-drill front plate options 20240420_153442
Ford Mustang Mach-E No-drill front plate options 20240420_153433
Just make sure that however you are attaching the mount, the license plate doesn’t block the forward sensors. That will lead to all sorts of complaints from the car. ??
rreddy3
Richard
2023 Mach e Premium AWD X
I bought a no drill front bracket from a Virginia based guy. He's retired navy and evidently remained in the Norfolk/Hampton Roads area, home of the world's largest navy base.
Craig's Custom Mustang Brackets (ccmustangbrackets.com)
To Steve's point about plate blocking or fouling sensors, my car wasn't complaining but I decided to add a couple of more holes to the plate allowing me to raise the plate about an inch. It actually looks fairly decent at that height. That set up seems to work but I may give the plate a couple of more holes and raise it a bit more, or not. I'm happy with this solution.
lesz
Les
2022 Mach-e GT PE
https://zicmoto.com/2021-ford-mustang-mach-e-expect-gt-removable-front-license-plate-bracket/
Does anyone have any experience with this brand? There seems so be tons of snap-on options for Teslas but so far not much for our car. I know it’s new though and maybe more will come on the market. Anyway, just wondering if anyone has bought this brand and if it works well?
yes, I use it on my 22 GTPE. I’ve had it on for about a year - been through multiple car washes - works great. Easy to takeoff if necessary with the attached pin.
