JohnFoxeSheets
- John
- Jan 29, 2022
- San Francisco
- Website
- johnfoxesheets.com
- 2022 Iced Blue Silver Mach E GT
- Retired Engineer
The 2026 has a heat pump which increases winter range, but at the expense of a much reduced frunk. If you do get a 2026, drive it awhile and see if you like the new suspension. If you feel it can stand improvement, the single biggest upgrade you can make is to replace the OEM Premium spring with Rally springs. Adding Eibach sway bars is a good choice as well. But keeping your 2022 longer is really the best way forward. I'll be keeping mine for the next few years; likely until the extended warranty runs out in 2030...
