Rear camera
Twayquan
Quanison
New York
2023 Mach e
Law Enforcement
I've had my 2023 Mach e GT for about 2 months now and I still learning. When I'm parked waiting for someone and touch the camera icon I only get the front view on the screen. I tried different ways to get the rear camera when parked and the only way is to have it in reverse. Is there anyway to activate the rear camera if you are parked? Thanks in advance.
FordMachEGo
SoCal
2021 Premium AWDx April 2021 build.
I believe the only way to switch it to the rear view is to put it in reverse as you mentioned. Working as designed.
Yup, the answer @FordMachEGo provided is correct unless your car was not equipped with 360 cameras like mine. Since you have a front camera, Ford assumes that you want to see what’s in front of you when you hit the camera button. My GT-PE has no front camera so I only get a rear camera view regardless. ?‍♂?
If you use 1PD, there’s no downside just putting it in reverse while parked. The car won’t move until you press the “Go” pedal.
