Resume Control Warning
Northofnine
Innisfil Ontario
Mustang Mach E AWD ext Premium 2021 Job 1 non EA
Hi all,
Fun trip home last night.
decided to use BlueCruise since I hadn’t in a week or so.
it kept kicking off and restarting. Once it flashed up Resume Control. Which I did. The warning disappeared.
A little later same warning on the screen plus the warning sound. Problem was that it wouldn’t shut off.
headed for the next exit and a gas station in case the car shutdown.
To add to my fun. That exit had a Police ride check. The officer looked at my dash, heard the noise. Asked if I had been drinking. I said no. Off I went.
got to the gas station.
Applied the when in doubt reboot approach.
Car came back to normal with no warning sounds. Made it home with no further issues.
Not sure if related. But a few days before I got a TPMS warning and the rear wheels showed a fault. This has happened before. When reversing into the garage my rear camera also showed a fault.
For that problem I used the drive it until it fixes it self approach. Which after a couple of start stops of the car it did.
The car has for the most part treated me well. Lately it’s been an adventure.
Ford Mustang Mach-E Resume Control Warning B937A986-5B32-4F69-B5E5-844DEBAC3C16
Ford Mustang Mach-E Resume Control Warning 370CA416-D234-4446-B3E1-37D854108CB6
Ford Mustang Mach-E Resume Control Warning F832A52A-E3D5-42C3-8FE7-898BDBCDA9C0
That's a bug I haven't seen for a while. So guessing you're way behind on software updates, you'll probably want to make an appointment.
Northofnine
Northofnine
Innisfil Ontario
@Mike G has been helping me with some info.
Car was just back from service beginning of March. Apparently this is what is showing up now.
So...catching up a bit...you did get a GWM update and it is the same update that equates to 4.2.1. (Meaning this GWM update superseded the old one, so when it updated it skipped the 4.1.1 version and updated to the latest instead).
That said you now have an APIM update in your list and that would be the new Sync UI when it installs.
Ford Mustang Mach-E Resume Control Warning 5E88D439-3476-4779-9942-5C8CF0537BBE
That HVAC is also new...this one followed the one that was OTA 3.6.1. I've asked our engineer friend and he's looking into why this one was released.
