Soap cannons
  • Thread starter Deleted member 19354
  • Start date
  • Watchers 12
Guest
Anyone have a favourite or what qualities should I look for. Not wanting to spend a large amount of $. Amazon would be my preferred vendor.
AngryMan
Living the good life
I have this one . I don't remember paying that much but it IS a good product
Ford Mustang Mach-E Soap cannons Screenshot 2025-06-02 at 5.37.45 PM
Guest
One thing to look out for is the connection . They aren't all for garden hoses . This one is
Yes I saw that. I want good quality without breaking the bank. I’ve been using the coin op kind and I need the exercise ?
FYI foam cannons work way better when used with a pressure washer (1000+ psi). A garden hose typically does not have enough pressure to get good aeration. You also need to use a car wash soap that's designed for foam cannons for good results.
I bought one at Lowes for like $35 a couple years ago, works fine for my use.
Guest
I bought Migular (sp) gold I think.
@Travlcub, one other thing to keep in mind about foam cannons is to be sure to meticulously clean them after each use. Usually that means running a jar of plain water through it. Follow the instructions for whatever cannon you settle on though.
Buh-Bye Tesla
Rick
US
Mach E Premum EAWD
FYI I use it with Rain X Spot Free
Gives loads of foam with either attachment. I use the hose attachment for a quick wash or when it’s cold. Otherwise I use a small electric power washer.
The soap really works as long as you’re not in hot sun.
