Touch-up Paint for Minor Dings
azboneman
Scottsdale AZ
2024 Mustang Mach-e GT
I've got a few small stone dings on the hood of my '24 Mach-e GT. The color is Star White. Anyone know of a good touch up pain that is easy to apply? I've used Chipex on another car but the company is no longer shipping to the US due to tariffs. Thanks.
profdraper
Paul
Brisbane, Australia
2023 Mach-e Select
https://drcolorchip.com/ brilliant
Jeff-NoVA
Jeff
Northern VA
2022 Mustang Mach-E Premium
I would get it directly from Ford. Tiny variations in shade bug the crap out of me.
Even among tubes of Ford touch-up paint there are color variations! But I've generally had good luck with OEM touch-up paints.
GreaseMonkey
Chicago, IL
24 Mach-E GT
In my experience, OEM metallic paint has too many flakes that make the touch up spot stands out. I think you’d be better off with a reputable non-OEM brand.
MachEMikeInPA
Pennsylvania
2024 Ford Mustang Mach-E Premium AWD
I used Dr. Colororchip to repair some chips and scratches I got when someone backed into my front end in a parking lot. Looks like new. But it’s a process to apply. Worth the effort, in my opinion. https://drcolorchip.com/
EasyPass
2021 MME Premium 4X, 2017 Fusion Energi PHEV
I've used TouchUpDirect (https://touchupdirect.com/) on my '21 Premium. My impression:
- Pricey
- Lots of colors and product options
- color and clear-coat mixtures
- straight forward use with included implements
In the end, it's nearly impossible to apply a touch-up without it being obvious that you have, but at a distance can be visually acceptable.
Monke
TX
Mustang
I used to buy several paint kits from ford online dealerships and the colors do not match because the metallic coating has to be applied after the paint. The coating layer does not stay and dissolve the original paint. I had a better luck getting touch up paints with metallic in the paint not the top coat from eBay.
AliRafiee
Ali
Seattle WA
2022 Mach E GT - Grabber Blue
Software Eng.
Touchupdirect has a good reputation.
- Pricey
I used touchupdirect for my grabber blue metallic during the shortage, and it was lighter and didn’t have enough metallic flakes.
You can thin out the OEM if you want to by spreading the paint on a cardboard and the dipping your applicator into the part that has the right about of flakes.
Use these applicators
https://a.co/d/a8We89x
HughJazzol
Norman
Miami
2024 MachE Premium RWD
Project Manager & Swim coach
Use your Ford points, if you have any, to order it from Ford. I bought a tube for $8, using few points, and it matched my car perfectly.
ChehRob
Rob
Seattle WA
ret
For touchups I've noted that what you see a few inches away is not what you see 5-10 feet away. Those two fixes likely will not be the same. Most of us want it fixes to be unnoticeable at several feet away. Pros can make it invisible at both distances.
