Winter wheels
Sobmartin
Leavenworth wa
2021 Mach-e Premium Job 1 , 2014 Lightning Flash
How critical are the specs on the offset a d center bore on the wheels? I found a set with a 40mm offset and 63.36 bore. Will they fit my Premium AWD?
Nklem
Norm
Coast of Maine
Subaru Solterra
Mechanical Engineer
https://tiresize.com/ great site. and
https://www.wheel-size.com/size/ford/mustang-mach-e/2021/
With those two sites you can get a great comparison of offset based on width and wheel specs.
I believe the hub size (Of the OEM wheel) is 63.4 mm. I purchased centering rings to 63.4 and my aftermarket wheels fit fine. 63.36 mm seems too precise to me. I am sure they are probably 63.4 mm. You can take a wheel of yours and measure the physical hub diameter as a gut check.
