Hammered
- Oct 4, 2022
- SE US
- 2022 PB F150, MME GTPE
If you don't use FDRS or didn't install the IPC update that first showed up the last week of july, ignore this thread.
During the last week of july, FDRS showed an IPC update that caused the issue (if installed). The update brought the IPC up to the 23's software prematurely / out of order. This update causes a failure that you won't even see any signs of outside of not getting updates. The GWM and APIM updates won't post to the car -- they were showing as available for sometime but when trying to install them they'd fail because of the 23's software on the IPC. They've since vanished.
There's no easy fix to this as an end user with FDRS and/or forscan. It can be seen on ford's end which is how I discovered the issue was present due to external assistance. Ford is going to have to fix this and they may be testing such on their end as their master system can be queried about the condition. As such if you're in EA and you're not getting the updates the thing to do now unfortunately is hurry up and wait. While ford should have told those about the issue, they've chosen to say nothing hoping to fix it before it was noticed. Well it's noticed and public. Your move @Ford Motor Company
EDIT: This was triggered by a premature IPC update released the last week of July and only pertains to those who installed it.. If you have FDRS, update regularly, and updated the IPC around the last week of july to the present, you've kinda put yourself into this hole upon further digging. It's being worked on behind the scenes.
IF you installed the IPC update mentioned above and have not had any subsequent updates, PM @benk016 with your VIN to confirm you're facing this issue.
