azerik
- Erik
- Jan 8, 2023
- Chandler/Flagstaff, AZ
- '21 Spacey Prem4x, '21 RX450H, 13 Focus EV
- DevSecNetOps, General PITA
This is a 8.9 mile round trip. As I was trying to leave my driveway I was trying to turn off the AUTO ac settings as the car thinks it's 91 out. It's 67. The cars temp sensor says 91, it kicked the Auto climate on to high and AC on. So I clicked a few times and the lag of the 4.1.2 on my Job1 caused me to click through the Auto button like 3 times through the full cycle and I cycled the AC button as well. I drive this 8.9 mile route twice a day (for nearly 9 years in another EV). Never has it registered 9 miles. Almost always 10.5 to 11 miles. Using the nav to return home from my daughters school takes me the same route I use to get to the school. It says 4.4 miles from school to my house and vice versa. The AC was off once I left the driveway. 0.5 miles down the road I had flipped to "this trip" because it was showing (in the little tile) 2.2 miles/kw. 4 miles later after a quick mile on the freeway it's showing 7.8kw/h.
I'm thinking it's acting like my FFE where if you cycle the AC you 'gain' a ton of range. Like 25+ miles of range. But if you cycle it twice it'll put you negative 5 miles from Key on (30 less than when turning the AC off) then if you cycle the AC again you'll get 20+ miles of range and the kw/h come up with something crazy at the end of the drive like 5 miles per kw.
@Ford Motor Company If I managed any regen at all it was a couple feet at most. It's really hard to try to calc milage range if the climate 'adds' miles to the trip you didn't drive. I can somewhat understand using the added miles to help estimate but no way my drive can be twice as efficient as reality.
