Battery Charge reading glitch?
sago
Sergio
Missouri
2025 Mustang Mach E AWDe
I used departure time settings for the first time and drove 4 miles in 28° F weather. Charge went from 85% to 86%. Range dropped by around 19 miles.
Has anyone experienced that? Should I be worried?
Today, the charge % has been going down as expected.
E90alex
Seattle, WA
‘25 MME GT
Just the computer updating its estimate of the charge level. Very common and not indicative of any problems. Can go up or down a few %.
Murse-In-Airy
Rod
Chaumont, NY
Mach-E ER AWD
Nurse
As the battery gets cold, the capacity actually decreases. So if you’ve got a 100KWH battery thats warmed to full potential, it holds 100KW of power. At 85% SOC its holding 85KWH. So you burn a 10 KWH and it’s down to 75KWH stored. But… the battery cooled off and it can now only hold 87KWH total. It’s now at 86% of its max potential at that temperature. I drove 14 miles the other day between work (where the car was plugged in so the battery was warm) and a hotel. The car stayed at 100% the whole way because as I used electricity the battery also cooled off.
guizmou
juliano
Agerie
BAP Lariat
What you're describing is quite normal in cold weather, especially if it was your first time using the departure timer. When preconditioning is on, the car uses battery power to heat the cabin and preheat the battery.
sago
Sergio
Missouri
Thanks for the feedback. Truly love how my mme drives and as battery technology improves I expect even more fun to come 🚗
