Battery charger recommendations
MoonRiver
Tampa Bay, FL
22 Mach e select, 07 Infiniti G35
Thinking about getting a battery charger, just get ready for a new 12v, then it needs to be fully charged before swapping.
Any recommendations?
rhougey
Rich
North California
Mine is a Schumacher SC1359. It is an automatic 3&15 amp charger compatible with AGM, and will automatically enter desulfate mode if the battery needs it. It shows % state of charge and charged battery voltage. It is working well for me.
OrchidMania
Miami Beach
Grabber Blue Premium ER
My husband has a 12v battery charger. Where do you connect it ??
rhougey
Rich
North California
There are charger connection posts provided by Ford. The location of them is marked on the top of the trim panel located between the frunk tub and the driver side front fender. Ford’s design is to remove the trim panel to access them. Many owners have drilled access holes above them in the trim panel and added removable snap-in access plugs in order to access the without removing the panel. Your charger should be compatible with AGM batteries.
