4sallypat
- Pat
- Mar 30, 2022
- Southern California
- Website
- www.kudo-ume-farms.com
- '23 MME delivered May '23 + '22 Lightning July '22
- Network Tech
Same here never seen an arrow sign - '23 MME with BC 1.2.Typically before I hit an excessively sharp turn BlueCruise just turns off. You can see where it will do it on the BlueCruise map too. Here's my favorite example where it quits, then picks up, then quits again. I'm assuming this won't change since 1.3 is technically "out" and the map still shows this unsupported section.
Having said all that, I've disabled adaptive speed control so it doesn't slam on the brakes when it sees a speed limit sign. I'm curious if it will still slow down less for a sharp turn. I have 1.2 and I've never seen that arrow sign, or maybe I've just missed it, but the car does slow down for turns not outside the BlueCruise supported map area. Maybe that arrow only shows up if adaptive speed is enabled?
LOL, not a lot of useful info above, but it's my experience.
I only use it on freeways and curves are not very sharp to make me want to slow it down, although I always have my brake pedal covered just in case.
