Beeping EVERY time I stop!
oadesign
Bob
Millbury, MA
oaddesign.com
Mustang Mach-E Premium Extended Range RWD
Interactive Design Director
Recently my ‘21 Premium XR started emitting a collision alert beep every time I stop, even when there are no vehicles around me. Has anyone encountered this? I’ve cleaned the sensors and camera lenses, but this made no difference.
oadesign
oadesign
Bob
Millbury, MA
oaddesign.com
Thank you…although my plate, mounted with a Sto n Sho holder has been on since 1/22, evidently it had moved or been bent the slightest bit, which I didn’t notice, but the cameras certainly did! After re-centering and tweaking the corners to make the plate flat again, the beeping stopped. Thanks again!
rhougey
Rich
North California
I’m glad you got the beeping stopped, but are you sure your radar is working properly with the plate mounted in front of it?
oadesign
oadesign
Bob
Millbury, MA
oaddesign.com
Yes, as it isn’t blocking a sensor and has auto-braked in the past.
rhougey
Rich
North California
The only reason I asked is because it looks like your plate is mounted directly in front of the radar panel (in the middle between the louvred cooling vents). Be safe.
