Car Off, Door Open Beeping
ricksta6
Rick
Chicago, IL
2021 Mach-E Select Rapid Red
I'm using PaaK and I just started noticing yesterday when I park, turn the vehicle off, and open the door, the vehicle beeps (same beep as when the car is on and you undo your seatbelt). It doesn't stop until I close the door. Is this expected? I wonder if it's similar or related to the alerting mechanism for leaving your key in your vehicle, or if there's an order of operations I need to change somehow.
highland58
IT Solutions Architect
Sounds like headlights. If they are in Auto, turn them off and back to auto. If they are not in auto or off, turn them to auto.
sdespain
NC
2022 Mach-e (Premium AWD ER)
Check your lights switch. There seems to be a bug, where it switches off "auto". I have had the issue where my lights stay on. Fix, move the switch to off and back to auto, and the beeping stops.
I don’t hear any noise when I shut the car down and then open the door. Also using PaaK. ?‍♂?
ricksta6
ricksta6
Rick
Chicago, IL
Okay yeah, that was totally it. Some sorta bug switched my lights off auto. Turned it back on and the beeping stopped.
Davedough
West BYGOD Virginia
Mach E GTPE , Explorer ST
Federal IT Sales Engineer
Its pretty common. Mine does this about once every couple of weeks
jdhzzz
Jeff
Connecticut
2021 Mustang Mach e AWD ER premium job 1
Systems engineer (retired)
Thank you. Came here looking for an answer for this issue. Your tip fixed it.
