Blind spot detector damaged and need replacement
Stallion
Bob
Wilton, Ca.
2022 Mace E GT
I discovered that the blind spot detector and mounting bracket on my 2022 machE GT are damaged and need to be replaced. I had a bad experience with the dealer and I am looking to replace myself. I have received conflicting information on the need to program or calibrate the new sensor - does anyone know if I need to either program or calibrate the new sensor?? If I need to - would you know what I would need to use? THANKS
If the angle is pretty close it might be okay after driving it a while. You'll have to try it and see. If the light stays on, then you'll have to have it programed.
Jerrytball
Jerry
Gulfport MS
2026 bmw i4 M50
I know from 2010 up to 2018 maybe even 19 the ICE Mustang always had that little Blindspot mirror built-in. I loved that. I’m not really a fan of the Bliss.
Ford Motor Company
Official Ford Account
Stallion
Bob
Wilton, Ca.
2022 Mace E GT
My VIN is
Ford Mustang Mach-E Blind spot detector damaged and need replacement 1715384104485-qh
Local dealers NOT to contact: Elk Grove Ford, Downtown Ford. Folsom Lake Ford would be OK
