Boot under load floor contents?
bluestripes
UK
Mach-E
Hi
I just got my mach E back from the dealership (after 6 months ... HVJB issue).. and wondering if I'm missing anything from the stowage under the load floor in the boot. I can't find my locking wheel nut key and there seem to be items missing, can someone please check theirs and confirm! Appreicate it!!
I have - have the towing pin, 4 bolts, tire sealant inflator kit and that's it.
portlandg
grahame
Dorset UK
Black RWD ER and loving it
Cabinet maker
Hi
what other items were you expecting to find? What you have detailed is all that I have that isn't mine. Have you checked the glove box for the locking wheel nut key?
bluestripes
bluestripes
UK
Mach-E
Thanks for checking - I have looked all over the car, all stowage areas and can't finf the locking wheel nut key.
The locking wheel nut key is the main thing I was expecting but I did notice there's stowage for other items and they're empty so one item missing made me think, what else?
hawkeye3point1
NH
What about the mobile charger, or do you have that at home?
Lost my lug key once, will never get locking lugs again. Better reach out to your dealer ASAP to get it replaced.
bluestripes
bluestripes
UK
Mach-E
This is all I've got - I think the item wrapped is the tyre sealant and inflator kit (looks like it from the manual) and then the 4 bolts and locking key missing.
I've emailed Ford CRC about it.. so they've misplaced my AC charger cable and locking key. Not great!
Ford Mustang Mach-E Boot under load floor contents? IMG_1210
Wonky_Donkey
Tony R
Norwich UK
2022 Mach-E RWD ER
Mines got: (left to right)
1 Tyre inflation repair kit
1 Towing hook (under tyre kit)
1 Ford Mobile Charger
1 Set of wheel nuts
You should also have a 6metre Type2 cable in a Ford branded bag somewhere as well - but that doesn’t fit under the boot liner with all the other stuff.
Ford Mustang Mach-E Boot under load floor contents? DA7F0BCF-31CD-4812-9168-DC1A4B38AAF5
bluestripes
bluestripes
UK
Mach-E
1 Set of wheel nuts
Okay so I've got all of that except the locking nut key then - I've got the 4 wheel nuts - I see you've got your key there I think. Thanks for the pic appreciate it! I've messaged and called Ford CRC they're on it now.
MachEMaster
Will
Canada
1997 GMC Yukon GT
Aircraft Maintenance Engineer
Wheel nut key should be in an Orange bag in the glove box.
Wonky_Donkey
Tony R
Norwich UK
2022 Mach-E RWD ER
