Can't change Plug & Charge settings in FordPass 5.0.3 (Android)
kennelh
Louise and Ken
Northern California
We received our A2Z adapter yesterday and decided to test out Plug and Charge at the Tesla SC while we were there. I went into FordPass to turn it on (I'd previously done this just to make sure it worked) but every time I tried to toggle the setting it would wait for about 5-10 seconds, then no change.
When I got home I hooked the phone up to my computer and looked at the logcat output. I noticed the app was reporting an HTTP 400 error when accessing the endpoint. I side-loaded a copy of FP 5.0.1 and voilà I was able to turn P&C on. Is anyone else noticing this?
Code:
06-21 09:02:04.928 17241 18065 I okhttp.OkHttpClient: --> POST https://api.mps.ford.com/api/paak/v1/pnc/toggle (88-byte body)
06-21 09:02:06.300 17241 18065 I okhttp.OkHttpClient: <-- 400 https://api.mps.ford.com/api/paak/v1/pnc/toggle (1371ms, 53-byte body)
06-21 09:02:06.306 17241 17241 W System.err: retrofit2.HttpException: HTTP 400
06-21 09:02:06.309 17241 17241 W System.err:    at retrofit2.KotlinExtensions$await$2$2.onResponse(KotlinExtensions.kt:53)
06-21 09:02:06.309 17241 17241 W System.err:    at retrofit2.OkHttpCall$1.onResponse(OkHttpCall.java:161)
06-21 09:02:06.309 17241 17241 W System.err:    at okhttp3.internal.connection.RealCall$AsyncCall.run(RealCall.kt:519)
06-21 09:02:06.309 17241 17241 W System.err:    at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
06-21 09:02:06.309 17241 17241 W System.err:    at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:644)
06-21 09:02:06.309 17241 17241 W System.err:    at java.lang.Thread.run(Thread.java:1012)
CameraCarl
Karl
Twin Cities
The only way I could charge at a Tesla Supercharger was using the Tesla app. What is this FP 5.0.1 and how can I get it and where do I sideload (?) it?
kennelh
kennelh
Louise and Ken
Northern California
It's the FordPass app. Once I found the latest version (5.0.3) wasn't working, I lokated an earlier version of the app and manually installed. This is only possible on Android phones, not iPhones.
The FordPass app lets you enable or disable Plug And Charge within the app. As far as I know, that's the only to manage it.
bbulkow
menlo park, california
Honda CRV
Code:
Same problem here.
I had a good p&c but wanted to disable p&c to try the app. Now when i try to enable p&c there is a please wait spiral then the slider moves back slider after about 3 seconds. No error message is frustrating.
Haven't chased down why, going to try clearing cache and storage before trying a side load (update, cache and storage clear did nothing).
Guess i am using the tesla app until they fix this don't have the patience to chase down the side load
Yes i am on 5.0.3
kennelh
kennelh
Louise and Ken
Northern California
Same problem here.
I had a good p&c but wanted to disable p&c to try the app. Now when i try to enable p&c the slider moves back under its own volition after about 3 seconds. No error message is frustrating. Haven't chased down why, going to try clearing cache and storage before trying a side load
Yes i am on 5.0.3
I tried clearing cache and storage but it didn't help.
Dustus
Dustin
Boise Idaho
2022 Mach E GT
I had issues trying to change the charge percentage yesterday and it was acting the same way. I found for whatever reason that after going out and turning on my car to accessory mode that everything worked immediately. Didn't have that issue in the past but it worked yesterday.
BMT1071
Glendale, AZ
21 MME SR RWD, 23 MME GTPE
EV Technical Trainer
I've had this issue since 5.0.0. I was hunting for my EA free charging balance and tapped on the text, not the slider, hoping for info. It turned P&C off and I haven't been able to turn it back on.
kennelh
kennelh
Louise and Ken
Northern California
I can enable /disable with 5.0.1.
BMT1071
Glendale, AZ
I may have missed trying while I was on that version. Any luck finding your EA balance?
kennelh
kennelh
Louise and Ken
Northern California
Update. Downloaded 5.2.0 and it's still broken. Back to 5.0.1...
