charging failure
Jago
Marta
Poland
MME
In my Mustang MachE, the type 2 AC charging input does not work, only the DC CCS cable can charge the car. At auto service, mechanics reset the system and checked the fuses and it still does not work. Has anyone had such a case? Has it been repaired?
I will be grateful for any information.
If it won’t work with any Level 2 EVSE, your onboard charger will likely need to be replaced.
Jago
Marta
Poland
MME
If the car still has warranty, will it cover the repair? Do you know any similar cases?
Yes, it will be covered under warranty. I remember a member here having a similar issue, but I don’t really remember the specifics.
breeves002
Sam
St. Louis, MO
2021 Mach-E GT PE
Take it to a Ford dealer. They'll fix it for you.
Jago
Marta
Poland
MME
I was and they reset the system, they checked the fuses and it does not work
To be clear, you have tried multiple L2 EVSEs and none worked? If so, return and explain that the process processes they performed did not rectify the issue. ??
Jago
Marta
Poland
MME
yeah, yeah and car still at the Ford dealer and they don't know what to do
