wmaney
- Wade
- Oct 12, 2020
- California
- Mach-e GTPE, daughter drives Ford Focus Titanium
FYI if you are a customer of this utility - their $300.00 NEW EV rebate will end at the end of February 2021. Their level 2 charger rebate will continue and it is $500.00. Interestingly, their USED EV rebate is $500.00 and will continue indefinitely. They also do not have peak / off peak rates. Currently they charge 9 cents per KW up to 500 KW and then 14 cents above 500 KW. The utility is installing smart meters and then they may have peak / off peak rates. Finally there site is currently having hardware problems that will take a few more days to fix. Should be up by next Monday (2/15) - if not, the women I talked to said if they are not back up by then, they can arrange to send you the paper work. You can apply for both the car rebate and the charger rebate (Ford Connect) on the same form. Apparently there are some things you can still do on the site.
