- Lee
- Jul 16, 2021
- Wisconsin
- 2022 Mach-E Premium AWD
- Sci/Eng
Battery temp and battery coolant inlet temperature. Also PTC heater output. When the battery goes into heating mode you'll see heater output typically 5+ kW and the inlet temp will jump up. You will also hear the hum of the coolant pumps running and coolant gurgling if you listen closely.What object in Car Scanner would you look at to see if the battery was being heated?
