Delete
  • Thread starter Deleted member 19900
  • Start date
  • Watchers 0
Guest
Delete
mattyhillnepp
Matt
Iowa, USA
2023 Mach-e Premium AWD Extended Range
Check after 7pm. I wonder if it’s estimating based on “current charge rate” or something.
PA27
Howard
Alabama
MME X
Similarly, plugged my 2023 Premium RWD extended battery in last night and wait to charge times (~3 hours later) were all correct as set but, estimated finish time was 15 minutes before I plugged it in ?‍♂ It had charged as set this morning when I unplugged it but my app was insistent that I had remote started the car and it would be shutting off in 15 minutes. Though it didn’t seem to be on, 2 hours later I forced the app to shut it off. Stray electrons roaming about or, second install of 6.2.0?
Gremlins
MillerPaints
Wendy
2023 Mach E Premium RWD SB
Yes, things were happening last night while on the charger... one or more software updates definitely got beamed down.
My spouse had a fit because the mirrors no longer folded in this morning after she parked and locked it. I had to do an emergency reprogramming in the menu system to calm her down.
We are periodically having this issue...and have had since the last update. What "emergency reprogramming" did you do? Thanks!
