Mach-DB
- Mar 21, 2022
- UT
- 22 Mach-E Premium AWD ER
I received update 4.1.3 about a month ago and since then both display screens on my Mach-E (22 Premium AWD, extended range) are dimly lit. I have tried rebooting the main display, adjusting the brightness control next to the headlight switch by the driver's knee, and adjusting the display settings on the main menu several times - all to no avail.
Since first owning the car my display settings for both screens were set on auto mode to adjust for day or night as needed. Since the most recent update the screens are now dimly lit at best and almost unreadable if it is sunny out. Under the General> Display settings is a slider control for Brightness. It will only go halfway which seems to be causing the dim screens. I tried the Reset button many times and it still will only go halfway.
Has anyone had this same issue, and if so were you able to figure out a way to reset the Brightness control? Any help would be appreciated.
