Does Disabling Reverse Brake Assist Disable Reverse Sensing?
QuinicAcid
Marshall
Home
Dodge Durango, Subaru Outback
Transportation
We took a Mach E out for a test drive, and tried it in our driveway. Backing out of the driveway the car saw the road (we have a steep driveway) and the car automatically applied the brake. We tried this several times, and it did it every time.
This was kind of a deal breaker for us... we don't want a car that hard stops every time we try to leave the house. The dealer suggested we disable the feature. We didn't get a chance to try it out, but it may work. However, we do not want to disable all of the other reverse sensing system.
So, my question is (for anyone that can test this), if we disable the reverse braking assist does that also disable all the warnings that the reverse sensing system provides?
Woeo
Woeo
Fusion Energi
Similar problem for me with my drive....
Suggest....disable one-pedal driving if enabled. This will allow the car to 'coast' down the driveway more easily. Less hurky-jerky motion as you are reversing.
Then, although this may sound counter-intuitive, as you keep speeds low accelerate through the car's attempt to auto brake.
When the car warns you it wants to brake, applying acceleration will indicate to the car you are in control and want to continue backing. Too fast though and the car will apply firm braking.
Turning off Reverse Braking Assist just stops it from automatically braking when it sees an obstacle while in reverse. It does not disable the warning sensors unless you also turn off Rear Parking Aid.
RyZt
San Jose
Mach E4X
Reverse brake assist can be disabled independently. Parking aid (sensor and audible tone) and cross traffic alert will continue to function.
On the other hand, if you disable parking aid or cross traffic alert, reverse brake assist will be unavailable.
leemoknows
Indiana
2026 Mach-e Premium Extended
Is it possibly the hill start assist that is doing what you described?
What is hill brake?
Hill Start Assist is a system that applies the brakes to hold your vehicle after you bring it to a stop on a slope.[1] This feature makes it easier to pull away without needing to use the parking brake.[1]
How It Works
When the system activates, your vehicle remains stationary for a few seconds after you release the brake pedal.[2] This provides time to move your foot from the brake pedal to the accelerator.[2] The brakes release automatically when:
  • You apply the accelerator and the vehicle begins to move forward.[2]
  • The system exceeds the time allowed for automatically applying the brakes.[2]
The system activates when your vehicle is in any forward gear and facing uphill, or when in reverse (R) and facing downhill.[2]
rhougey
Rich
North California
I used to have that problem in my daughter’s driveway. I found over time that if I turned at a bit of an angle as I approached the road, it didn’t do it. Your driveway may not work with this if it’s narrow or steeper.
