Reverse Assist/Steering Center Find Procedure
pikepilot
New England
22 MME GT
Anybody have an official document from Ford describing the procedure to reset the Steering Center Find after getting the Reverse Assist Not Available-See Manual msg?
I know the procedure, just looking for the official document from Ford concerning what it is and how to do it. Had a copy at some point but lost it.
Steering center is found within the first 30 seconds of driving between 9 and 30 mph. Get the car going straight, and try to let go of the wheel for 5+ seconds at a time.
Teslaeata
Nottingham, England, UK
Does this demonstrate the value of regular wheel alignment/adjusts?
pikepilot
New England
22 MME GT
Again, just looking for a document from Ford stating that Fault is normal and/or the detailed procedure to recenter/recalibrate it.
Teslaeata
Sorry, can’t help, never needed it.
Good luck in your search.
What's the context here of needing a document when you already know the procedure, are you trying to prove something to a dealer?
If you have the exact code, that can be looked up in the workshop manual, and the relevant pinpoint test will detail the procedure and steps involved to fix it.
If you are getting a Reverse Assist Not Available message every time you drive the car, that is not normal. It can be a one-time glitch that goes away after you drive the car, but if it stays longer than that it should be fixed.
