Doors not consistently propping fully open
Sabbaspar
NEW JERSEY
Mach-E
Hi all. For about a week my driver side rear door does not prop all the way open in the cold. My kid must stick his tiny fingers between the fender and door edge to pry it open. Seems dangerous.
It's going to be tricky with a sheet of ice on it where one could normally grab the door handle for a little extra ummph. Wishing for a proper rear pull like the front that wont snap off like the aftermarket ones.
Mrn
Pima County
MMES
Aviation
I've also noticed inconsistent opening of my driver's door. I've been experimenting with shorter and longer presses to see if there is a pattern but so far haven't seen one.
Sabbaspar
NEW JERSEY
Mach-E
Same here. Trying to identify a trend. My kid's door doesn't quite pop open enough and he must stick his fingers in and under the lip to pull door open.
Mrn
Pima County
MMES
Aviation
ps. It doesn't seem to be a winter vs summer thing since it happens in a relatively warm garage in Tucson.
Sabbaspar
NEW JERSEY
Mach-E
Hmm. Good call. You're right because we had a 60 degree day here in NJ just last week and it still did it.
SprManKalEl
Gerry
2022 Mustang Mach-E Premium AWD
Wait.....are you saying it doesn't open at all? It never will come fully open on button press. The same as the front doors. It is not designed to. It pops open and the plunger stays in place to prevent the door from closing again. That is until you begin to pull the door open. Then the plunger retracts as it thinks the door is being opened to allow a passenger in and then be closed. If you don't want your kid to stick their hand in the opening, get the aftermarket handles for the back doors.
Sabbaspar
NEW JERSEY
Mach-E
Thanks for the reply. My rear door does not pop out like the rest of them do. The rest pop open about 3 inches upon pressing open button, just enough for fingers to get behind to pull door open. My driver side rear door makes a pop sound, but only projects out a millimeter or two...not a enough to gey hands behind to pull open. I literally have to open drivers door and push door open from inside.
SprManKalEl
Gerry
Sounds like you need to take back to get serviced.
gordonf238
Gordon
NYC
Mach-E AWD, Ext. range
Yep, leave it to the car companies to reinvent something as simple as a door handle. Because God forbid Ford doesn't mimic Tesla in every shape and form.
The whole obsession with seamless, electronic door handles is beyond my understanding. It's not innovation. It's cheap gimmickry designed to appeal to a primitive consumer mind.
Sabbaspar
NEW JERSEY
Mach-E
Even if they took the Lincoln Continental door handle style, but in black, and allow for a physical pull handle that could still be sleek and different. The push button is proving problematic.
SprManKalEl
Gerry
I don't have a problem with the way the door opens. I quite like it actually.
Earplug
Jack
Colorado
2022 GT-PE
Mrn
Pima County
MMES
Aviation
Mine is a bit different. Usually it works fine, but occasionally it doesn't respond at all until I've pushed it several times with my finger.
gordonf238
Gordon
NYC
My favorite thing is when the door opens when I'm power washing the car and the spray hits the button. Love getting the interior wet.
