Drivers Side Rear Marker Light Stuck On
ValentinoRossi
21 Mach-e Premium AWD ER (10/21 build)
I don't think my driver side rear marker light ever turns off. The one on the side of the car.
I wonder if it could be the cause of or related to this problem I have that some think could be from the 12v battery being low: (35) Did they change the Chime or Is Something Wrong? | MachEforum - Ford Mustang Mach-E News, Owners, Discussions, Community
Also does the auto high beam not work until the car is "warmed up" for anyone else? especially when its cold out, it doesnt work until I've been driving for a while. I know the speed requirement, it's not that.
Lastly, I guess still no perm fix for the headlight switch getting stuck between modes? Is it possible to get it fixed udner warranty or its just a "feature" (bug).?
Thanks!
If by “headlight switch getting stuck between modes” you mean the switch randomly switching the lights on, the new switch has been out for almost a year. Since I already placed a liftgate switch into that switch cluster I bought one and installed it myself. There is a TSB for it that will allow replacing it under the 3 year warranty. ??
I don’t know about the other things. I don’t often get to use the auto high beams. My other lights are not stuck on. ?‍♂?
Snakebitten
Coastal Texas
2023.5 Mach-E
I think auto/beams requires a minimum speed? I know at night I have to exceed the speed limit on my immediate road by a couple of mph to kick it on.
The fix for the headlight switch has been out for a while, you need to replace the headlight switch to fix the problem. See this bulletin: https://www.macheforum.com/site/thr...n-on-by-themselves-when-vehicle-is-off.28571/
Marker lights should turn off. Something weird is up if you manually turn the light switch off and they stay on still. You might have some kind of short or a bad BCM.
Auto high beams should work as soon as you hit about 35 MPH provided it's dark enough and it's not picking up any light sources in front of you. There is maybe a short delay, mine kick in after probably 1000' or so.
Ford Motor Company
Official Ford Account
Thanks!
