EA Congestion Pilot Program
  • Thread starter Deleted member 19354
  • Start date
  • Watchers 5
Guest
I enjoy how it’s all mostly high density urban areas.
And a Sheez in a town of 3k.
Looked like mostly LAX SFO And a few others. Kind of surprised Seattle is not on the list.
Charge_Rob
Dearborn, MI
2024 Ford F-150 Lightning (2025 Mustang Mach-E Rally on the way!)
Charging Nerd
That Sheetz is a constant bottleneck crossing Pennsylvania. Heads up to anyone traveling through, hopefully this helps but I will still avoid that location.
Sikkun
2023 Mach E
I assumed, just seems random compared to the rest of the list.
R1Tims
Central Il
Mach E GTPE, Rivian R1T
Consultant
This is assuming the EA charger works, provides an as noted charge rate or does not throttle down to 40kw 2 min after you start. Wonder if they restart the timer when you have to unplug and move to another plug at the site because the current one you use does not provide anything more then 40kw. That is assuming there are more than 1 working.
I avoid EA at all cost!!
milepost1
harold
bonney lake
Carbonizied gray - FE
I have noticed a marked improvement at the EA stations i have used.
TheVirtualTim
Dearborn, MI
I used that Sheetz twice … two years ago. At that time it was not congested. It was only 4 stalls.
The bigger problem with EA … is I cannot remember the last time I was at a site where all the stations actually worked. Usually at least one station is completely down … and at least one or two others are de-rated. Unfortunately, this means that there may be just one fully-functional stall.
Haydn12
Chandler, AZ
Mustang Mach-E, Toyota Prius Prime
I ran into this Congestion Pilot in Yuma, AZ. They were not supposed to be doing this on major expressways but they were doing it on these chargers. I could not get past 80% charge as it was only outputting 4-5 kw. Tried to move to another charger but it wouldn't connect. I was at a 350 kw charger but it only got up to about 90 kw which was terrible speed. So after spending 30 minutes there, I needed another charge in El Centro, CA to make sure I could make it all the way to San Diego. The El Centro chargers sucked with only 1 working. Had to call to get another one reset. I could have make it all the way to San Diego from Yuma but I don't like chancing it.
On the return trip I stopped in Yuma again. This time I connected to one of the 150 kw chargers. I was getting 172 kw for almost the whole charging session. I was able to charge to 95%. Maybe the Congestion pilot doesn't work on Sunday evenings.
How do you know they were doing it in Yuma, vs. a charger not working properly?
I have found that often the 150kW chargers work better than the 350s.
