Failed Driver Mon Update then 6.14 completed
Mustang-Mach-G
Gary
Boston
2022 Mach-E Premium
Is there an easy way to check if 24-PU0105-CMR-FX update worked?
screen said failed and Ford would "resend"
24 hours after the Driver Monitor update Failed
6.14 installed and completed fine.
Neil4Real
There’s the post here thread to check what FDRS updates you have. There is a bug when getting back to back updates, the prior update, even if completed successfully, says failed or not completed when you check the software update section. This usually means it’s downloading the next update and when you check for updates again after a while, you’ll see the next update’s notes. If yours was truly back to back, this could have been the case.
