nurspouse
- Feb 3, 2026
- Pacific Northwest
- 2024 Premium
For climate control, I almost always have "Auto" off, and manually set the fan speed to 5.
The problem I'm seeing - sometimes I increase the temperature (too cold outside). I still want air on my face, but I want it to be warmer.
What I'm seeing: Often, past a certain temperature, the air blowing from the front vents drops when I raise the temperature, causing a lot of discomfort.
To reproduce:
1. Turn off "Auto"
2. Turn off AC
3. Set temperature to lowest.
4. Set fan speed to 5.
5. Set air to come only from top vents
Put your hand in front of the driver air vent (the one in the middle) to gauge the amount of air coming out. With other hand, raise the temperature to something pretty high. After a few seconds, you'll see a noticeable drop in the fan speed.
(I think it will eventually return to the usual fan speed once the temperature has been reached, but that will take a long time).
I assume this is normal?
To reproduce:
1. Turn off "Auto"
2. Turn off AC
