FDRS Installed (after a few teething issues) .... car now updated
Mjansari
Manish
UK
Mach e Awd ext range
Hi ive purchased a 24hr Licence (im based in the United Kingdom we dont have a 2 day option), ive installed FDRS, when i try and connect i get the attached error. Am i doing something wrong, also i need to install IDS before installing FDRS?
Any advice would be much appreciated.
Ford Mustang Mach-E FDRS Installed (after a few teething issues) ....  car now updated IMG_7690
Ford Mustang Mach-E FDRS Installed (after a few teething issues) ....  car now updated IMG_7693
WyldStallyn
Jody
New Hampshire
2021 Mach-E GTPE
You will want to uninstall FDRS, download an older version (search for a link to download 37.4.7), install it and you will be able to log in. After you log in successfully you will be able to upgrade to 38.5.7 and use it successfully.
I would return the license before you go through this process.
rugedraw
Javier
Miami, FL
Auto Sales
You can get the older version of FDRS below:
https://github.com/nitrobass24/FDRS-Archive/releases
I recommend 37.4.7.
Edit: The error message you posted is showing FDRS has no online connectivity. Maybe a dumb suggestion, but make sure your wifi signal reaches wherever you are working on your car.
Arjan
Arjan
NL
Ford Mustang Mach-E GT Performance
Looks like the same issue i got with FDRS, in my case it was the wrong language version installed. An older FDRS version also helps.
Mjansari
Manish
UK
Got it installed, started at 2pm and finished at 11pm. I have a dedicated battery support unit (can supply upto 80amps), the car did not draw more than 30amps throughout.
Happy with the results.
Ford Mustang Mach-E FDRS Installed (after a few teething issues) ....  car now updated IMG_7703
Ford Mustang Mach-E FDRS Installed (after a few teething issues) ....  car now updated IMG_7704
Ford Mustang Mach-E FDRS Installed (after a few teething issues) ....  car now updated 3ECF8C22-55F4-4DEA-BC3C-3CB8483A9309
Ford Mustang Mach-E FDRS Installed (after a few teething issues) ....  car now updated IMG_7700
WyldStallyn
Jody
New Hampshire
2021 Mach-E GTPE
Glad you were successful. Can you please confirm how you got FDRS working? Did you follow the recommendation to downgrade FDRS to an older version and then reinstall?
Mjansari
Manish
UK
yes i downgraded to a older version and then updated as it would not connect to the servers with the latest version
WyldStallyn
Jody
New Hampshire
2021 Mach-E GTPE
Thank you for the confirmation. That was my experience when I ran into the issue so I'm glad to see you were able to reproduce the solution.
Jeff-NoVA
Northern VA
2022 Mustang Mach-E Premium
I wish I'd found this thread about a week and a half ago when I experienced the same login issues. I will try FDRS again, but after my HVBJB service is completed.
