First Plug and Charge Using Lectron adapter
Max Power
Gabe
Yorba Linda , CA
2023 Mach E Premium RWD Extended Battery
After receiving the update for plug and charge with Tesla I was anxious to try it out. Last night was my first time to need to do so. I can say it went flawlessly! I plugged in and I initially didn't think anything was happening, I opened the Tesla App and chose the stand I was plugged into and it said I wasn't able to charge there. I closed and tried again and same error. I then open the Ford app and it indicated I was charging! I didn't see the usual graphic on the dash indicating charging but when I got out of the vehicle I could hear the charger going and the blue lights on the charging ring were on. So if I would have just opened the Ford app I would have seen everything was good to go. I have had a real hard time disconnecting my Lectron adapter from the Tesla cable in the past, but this time I pushed the disconnect button on the Mustang charge port and waited 10-15 seconds and could hear the charger spooling down. The plug came out on the first attempt. In the past it has taken my 5-10 mins struggling and even asking for help from a Tesla owner. Overall a great experience so nice to have that Tesla option, even though I don't like given Tesla any of my money.
ToOldForThis
Jeff
2021 Mach-E Premium 4X
Technical Analyst
I have no personal experience with this, but I believe I read that if you are going to use the Tesla app to charge, you have to initiate the charge BEFORE plugging in. Otherwise, the Ford Plug-and-Charge takes control of the port/charger.
dtkindler
Chicago
2023 Mach E Premium
Photographer
Same experience. Used my Lectron Vortex a couple of times and had zero difficulties. I was thrilled when Ford Plug and Charge just worked with no intervention.
