Ford Update 24B60
Oldlawman
Essex UK
"Rosie" - Rapid Red Mach E AWD EXTD
Hi guys,
Just had my Mach e AWD EXT (Rosie) into Ford for her 2 year service plus the above software recall update to the braking system. Mine was not affected by any braking fault previously and I understand that only some vehicles were affected. Anyway I invariably use one pedal driving with untamed and rarely used the brakes as I clould judge the stopping distance accurately just utilising the regeneration. In traffic or reversing the regeneration factor was really strong and made the car manageable. Following this software update however the regeneration factor has lessened considerably especially at low speeds and when reversing. Once the car starts rolling in traffic or reversing it will only stop if I use the brakes which I don't like at all. I don't know if this has been caused by the software update but has anyone had this sort of experience. I don't know if I am making an unnecessary fuss but my car has changed to something I don't enjoy now. I have booked into Ford for a check next week just in case.
AliRafiee
Ali
Seattle WA
2022 Mach E GT - Grabber Blue
Software Eng.
Have you checked to make sure 1p is still on? Turn it off and back on
I agree with the other two responses. OTAs have been known to reset some or all personal settings. Check all of the options you have set to make sure you’re set correctly. Also make sure that the profile the car is using is yours. ??
MuckyMach-e
Liverpool, United Kingdom
Ford Mustang Mach-e AWD Extended Range
I had the update 2 days ago and have not noticed any difference. I typically drive in whisper and 1PD on highways.
Oldlawman
Oldlawman
Essex UK
Hi everyone,
You would think that after 2 years I should have remembered that the update could have switched some settings. I know that I am shortsighted but I should have clocked that the 1pd was turned off?All good now thanks. (I’m rather embarrassed?)
Hi everyone,
That’s what the forum is here for: To remind us that Cats are superior to humans and Poodles superior to all. ??
Oldlawman
Oldlawman
Essex UK
No - you mean Airedales?
