Status
Not open for further replies.
Lb8403
Washington
2022 MME Premium EXT AWD
Shots while not suspended on floor jacks. ??
Frontal shots. ??
Left.
Right. Note the real SUV in the background. ??
Rear shots. ??
Left.
Right. The tires stick about 1/3 of the outer tread block out from where the @AOSK mud flaps extend. I am going to leave it as is for now but if I find that I need wider mid flaps I’ll switch. ??
Nonsense pix. ??
Got the same offset as you, and going to go with the Hankook ION EVO AS. Hoping they sit flush with the AOSK mud flaps. ??
9.5” width rims? What size tires? ??
Sorry 20x9 AW11 +38. 255/45R20XL
9“ with the same offset and 20mm less section width… The tires will still be proud of the mud flaps, but not by much. ??
Panzer948
Charlotte, N.C.
2023 MME GT PE, 2021 Ford Bronco, 2015 BMW M4, CJ5
Geologist
Frontal shots. ??
Left.
Rear shots. ??
Left.
Nonsense pix. ??
Looks great! Thanks for sharing as it gives me ideas down the road.
Atomic Wheels
Atomic Wheels
Dallas, TX
Many
Here are some pictures of a custom order featuring the stunning AW12 20x8.5" +40 rims for the Mach E. They are packed and ready to be dispatched directly from the factory to the client.
We are hopeful that the client will share images of these rims once they are installed on the vehicle.
Lb8403
Washington
Just got my AW12’s in!
Next up: Ceramic coating them, then getting them wrapped in Hankook Ion EVO AS
More pics to follow!
Thanks to Serg and the AW team for their responsiveness and excellent customer service!
If you truly want a customizable fully forged wheel, that isn’t going to cost you an arm and a leg then look no further than AW!
Lb8403
Washington
What color is that? Looks like anthracite silver but turns black at an angle ?
Atomic Wheels
Atomic Wheels
Dallas, TX
Many
Hello, we currently have approximately 800 wheels in stock, with 95% designated for Rivians and Teslas. We're contemplating introducing an additional design for the Mach E, specifically the AWZZ, our top-selling and lightest wheel. This addition could enhance both range and acceleration. Remarkably, the 20x9 model weighs less than 20 lbs! Given the Mach E community's limited size, we aim to avoid overstocking colors that may not sell, keeping our inventory lean. Could you suggest which color we should stock?
Here are some pictures of the satin black and titan AWZZ for the BMW M3/M4
Lb8403
Washington
Just my two cents,
For Teslas - would imagine most would go with a stock look so (satin black).
Rivians - would imagine the same. Gun metal, anthracite or whatever color matches best to OEM.
MME - IMHO, Gloss black. It matches the piano black trim. This is what I got for mine.
PRO Tip:
Get them ceramic coated before putting tires on them. Will make cleaning easier and have them looking like new longer.
Future AW item proposal:
Forged Lug Nuts to go with your forged wheels with subtle moniker (eg “AW” or “A”) and protective sheath on rotor facing end. See link below:
https://vossenwheels.com/lug-nuts-bolts/
Atomic Wheels
Atomic Wheels
Dallas, TX
Many
Just my two cents,
PRO Tip:
Gloss black - it's exactly what we were thinking about. Your ideas about lug nuts are also worthy; thanks. What do you think about [AWZZ] as a design for Mach E?
Lb8403
Washington
I like the AW11 look for the MachE. It obfuscates just enough to look akin to the GTPE OEM wheels. But that’s just my personal opinion.
@HuntingPudel - Thoughts?
I like them both. The AW11 in gloss black has a sort of similar feel to the GT-PE Nite Pony wheel. I actually wanted something more like the AWZZ but since it wasn’t available with our center bore size and lug spacing, I chose the AW11. I am happy with what I got. But, the grass is always greener. ??
Nathanml
Nathan
St. Louis
2023 Mach-e GTPE, 1996 Corvette
Are the AWzz available?
Status
