Headlights Auto Dip at Night
Ravinghill
Simon
UK
Mach E SR AWD
Ivenoticed recently that my headlights weren’t auto dipping. Not sure when they stopped working as I haven’t had many drives in the dark recently.
Went into the on screen menu to check that the auto dip headlights setting was not there !!!! Has this feature now disappeared ? Or is it always on now ??
Anyone know where this feature has gone or how I can turn it on again ?
Deleted member 19354
Guest
Double check to see if you have the auto on? I’ve not had issues (yet)
If you are talking about switching from low beams to high beams and then back down, in the US that requires a certain speed. Also, if you manually switch to high beams, it disables the function, and you have to do that again until the "A" for Auto shows up.
AliRafiee
Ali
Seattle WA
2022 Mach E GT - Grabber Blue
Software Eng.
Move the stalk back and forth until the highbeam symbol with the A shows up.
Mrn
Pima County
MMES
Aviation
Did you look at the manual light control knob? In my US car it's near the left knee and has about 4 different settings. Mine is normally set on automatic for headlight control?.
Kevstone
Kevin
Uk
Mustang Mach-E AWD X
As AliRafiee says - it takes three goes, Hi beam on, Hi beam off and Hi beam back on again to go back into auto. Well that works on my car anyway ?
