Inner Tail Light
Ned Nucleon
Mooresville, NC
'25 Mach e Premuim
TV Station Manager
I have a '25 with a cracked driver side inner tail light. If I were to buy a used replacement, can I buy from any model year, or does the '25 require a tail light from that year?
markw314
Sterling, VA
2023 Mach-E GT
I believe the taillights on the 2024 and 2025 have the same part numbers.
Ned Nucleon
Ned Nucleon
Mooresville, NC
'25 Mach e Premuim
TV Station Manager
I continued looking and found out that there are differences with the flash pattern from the '25 vs previous years. Someone posted a video of their hazard lights on, and it was immediately noticeable. I guess I'll have to buy new, or really make sure I buy a used '25.
HughJazzol
Norman
Miami
2024 MachE Premium RWD
Project Manager & Swim coach
does anyone know if there's a 3rd party (aka cheaper) alternative to RJ8Z-13405-A:
https://ford.oempartsonline.com/oem-parts/ford-lamp-assembly-rear-stop-and-flas-rj8z13405a
look on ebay. I have a cracked inner taillight like you, and several members pointed to ebay. Even used, I couldn't bring myself to pay $250 for a used one, so I sealed the crack with clear silicone. Obviously I don't see it while driving, and it isn't overly noticeable.
Here's that thread. My picture in the last post is not how I left it. I reapplied the silicone and smoothed it out with a wet finger, and painted the border black. It looks ok.
https://www.macheforum.com/site/threads/tail-trunk-light-cracked-aggghhh.52767/
Ned Nucleon
Ned Nucleon
Mooresville, NC
'25 Mach e Premuim
TV Station Manager
Unfortunately water has gotten into the light, and it no longer works. I will keep an eye on eBay, though.
HughJazzol
Norman
Miami
i saw mine filled with water, but it still worked. I drilled a tiny hole at the bottom for the water to drain. Good luck.
Ned Nucleon
Ned Nucleon
Mooresville, NC
'25 Mach e Premuim
TV Station Manager
I did the same thing, but it still failed. Going to check some local junkyards to see if I get lucky.
