IPC Module programming may failed. Black Screen.
DMIINC
Dalibor
Georgia
2015 Ford Explorer, 2021 Mustang Mach-E
Real Estate
Hello,
Was doing updates yesterday and title of this thread suggests IPC programing has failed. All I have is black screen.
Message in FDRS states the following when trying to run Self Test:
Test could not be started. Module programming may have failed. Address any programming related issues before further diagnosis.
I do nor know what led to failure I walked away after updating started since I was doing something else in the front yard.
Is there a way to back door program this? All attempts via standard FDRS procedures are not working.
2021 Mach-E EX AWD
The IPC update is relatively quick, but requires a USB flash drive and at least one restart of the car. Even though it may look like it's done, you have to leave the USB drive connected to the car until it specifically says to remove it. Then you have to hit yes in FDRS and let it do its final config over OBD. This one's not really a good one to walk away from while it's installing.
Ford Motor Company
Official Ford Account
Hello,
2021 Mach-E EX AWD
Good afternoon, Dalibor! Could you please send us a private message with your VIN and dealership information? I would like to look into this module programming concern for you on my end. Thanks!
DMIINC
Dalibor
Georgia
Real Estate
Message sent!!!!
Thank you!
AjzRide
Alan
Houston
RR 2021 MME Premium RWD
Eng
@DMIINC Did you get this resolved? I've managed to bugger my IPC in FDRS as well.
