Key fob only works driver's side windows
Mustang65
Andy
2023 Mustang Mach E GT Performance Edition
I bought a nearly New 2022 GT performance model. In learning all the features I found that I can use the key fob to roll down all the windows. (Press unlock, press and hold for 3 seconds) However, on my car the process only rolls down the driver's side windows. The setting in the car that makes the fob process work is on, and I don't see anything that would account for this. The right side window controls all work just fine. So I am completely puzzled. I wanted to see if anyone else has had this issue before I call the dealer. Thanks.
i8iridium
Pat
Fort Washington, MD
2022 Mustang Mach E GT
U.S. Air Force (ret.)
Does the one-touch up/down work on those windows if you're in the vehicle using the door buttons?
Mustang65
Mustang65
Andy
Yes, the one-touch up/down works just fine from the door buttons. I initially thought that this might be related to having my phone as key and the fob both near the car, but I've proven that it doesnt matter. The passenger side windows don't respond to the fob open/close process. Any ideas would be appreciated.
JohnnyForensic
VA, US
Digital Forensics
Aren’t you supposed to double click and hold the unlock to tell it to do all windows?
Mustang65
Mustang65
Andy
Yes, and that is exactly what I am doing. There is no literature that I can find that says anything about opening only some of the windows with the key fob. I guess I'm going to have to take it to the dealer.
Perform the calibration process on the windows that don't work and try again:
https://www.macheforum.com/site/threads/window-calibration-every-time.8088/post-212793
Mustang65
Mustang65
Andy
Awesome! It took a few tries, but that did the trick! All 4 windows now raise and lower together as they should. Thanks much!
azerik
Chandler/Flagstaff, AZ
DevSecNetAIOps, General PITA
I've had this do all kinds of odd things when trying to use it. All windows down then only the front up. All down then all but RR up. All down, only RR up.3 Down driver never moved. I'm not sure it's the calibration but I'll give that a whirl the next time I key on.
