EMachE
- Enzo
- Sep 22, 2020
- YEG
- Mach E, Escape Hybrid
- Mechanic
There is an antenna on both sides of the vehicle, one in each rocker panelHey there guys,
i am sharing a small update.
I dropped the car to Athens local repair shop, after Ford instructed them to check some cabling.
The inspection didn't provide anything new so they are waiting for more instructions.
The good thing here, is that they did a 12V recall, and updated all available module updates (IPC, and 2 more) which fixed the issue that Traction Control couldn't get disabled. Fun fact, The IPC update one came OTA just the same day going to the repair shop.
I informed them about this, and they ve already ordered a right side sensor (even there was no DTC errors). They told me that the part is only on the right side of the car. Is that true? Can I check the parts of the car with my VIN number? I can't believe the antenna is only on the right side.
Last but not least, i asked the repair shop to check/change these antennas/sensors, and if nothing happen maybe check the GWA to be faulty and replace if needed...
