Left Driver Rear Tail Light Flashing Randomly.
Amer Kh.
Amer
Iraq
Mustang Mach e GTPE 2023
Accountant
Hello,
Finally, I got my MME GT 23 GTPE from the U.S*. and after replacing the driver's rear backlight**, I noticed the Left Driver Tail Light*** was flashing randomly sometimes, but yesterday when it was charging, I saw the charging blue light flashing randomly too****, so I disconnected it immediately. and this morning, I tried everything, and it was good. So, do you think the problem is the tail light?
* The car hasn't charged since August 2024 even now, but it was 30% when I got it.
** The backlight I bought, its OEM parts from China.
***The tail light has a small difference my car's clip is 7 pins and the tail light has 6 but the clips generally are the same.
****During the video you can notice the blue charging lights are flashing randomly.
E90alex
Seattle, WA
‘25 MME GT
I don’t see anything wrong with the charge port light? It’s suppose to pulsate while it’s charging. Each section represents 20% of the battery so the third section flashing means it’s charging somewhere between 40-60%.
The tail lights might be incompatible because the turn signals flash differently in the rest of the world than in the US. Does it seem to function normally when you turn on the turn signal?
In the US, all 3 sections of the amber turn signal turn on at once and then they turn off sequentially and “shrink” from the inside out. In the rest of the world the light turns on sequentially and “grow” from the inside out.
The blue charge port lights pulse while charging. The flickering is caused by a camera artifact (rolling shutter effect, not real). Nothing wrong there.
If you want your taillight to work, you have to order one from the USA, not China.
Amer Kh.
Amer Kh.
Amer
Iraq
Accountant
Thanks a lot for your help. Unfortunately, you can see it with the naked eye, too. And the taillight, They cheated me. They didn't mention the problem of the U.S. and the other different versions.
Amer Kh.
Amer Kh.
Amer
Iraq
Accountant
Thanks a lot for your help...
