Lightning key fob
Sobmartin
Leavenworth wa
2021 Mach-e Premium Job 1 , 2014 Lightning Flash
Finally got the Lightning key fob from the online site. Tried all the programming instruction on the forum and failed. I had a ton of Ford points so I had my dealer program for points. They quoted an hour but was done in 20 minutes. I walked out and pressed the Frunk button. Click click and it opened.
Pibe38
Orlando, FL
2022 Ford Mustang Mach-E Premium X
Would you mind sharing the site you purchase the fob from?
Even considering the fact that when I followed the factory provider the programming failed, it took all of 6 minutes to program my F150 Lightning key. 20 minutes must have been multiple times following the factory procedure and failing. ?‍♂?
Sunburned
Dale
NoVA
2023 GTPE
Got my fob today from the ebay link above and it took two tries to program it. It worked when I didn't press the brake while pushing the start button on and off. Immediately able to pop the frunk, so much better than a two-pull handle or keypad or app or interior screen button!
