Emergency Fob Key
GenoToledo
Geno
Toledo, OHIO
Mustang Mach E
Can someone tell me what it is good for / what is it used for. Thanks
Dave159
2023 Ca Rte 1
If your refering to the key blank thats in the fob It has no real use, maybe to pry open the fob to replace the battery
AtomicInternet
SC
Focus RS, Mach E Premium
Can you explain what an "Emergency Fob Key" is? I only know of full permission (admin) keys and "My Keys" designed for teens that limits vehicle performance/features.
AtomicInternet
SC
Oh the pop out blank is for opening packages. No other purpose.
You people lock creativity. :inspect:
Nose picking tool
Scoop earwax out
Sharpen and use as a shiv
Lock picking if you grind it down
Kygolfer
Roy
Kentucky
2025 MachE GT
I’m a man. I use mine as a toothpick.
kamorela
Kelly
Beaverton, Oregon
I drove Fusions from 2014 until my Mach-e. The Fusion fobs had an actual emergency key in the fob, but you had to pry off the plastic cap from the door handle to expose the lock. I used it once just to see how and if it worked in case I ever needed to use it, which I didn't.
NY_Cade69
Cade
Ford decontenting, no whetstone included. 😠
