Emergency key
Brammy
paul
shropshire, uk
Mach e 23 on 24 plate. Grabber blue
retired violinist
Hi, my key fob has an emergency key inside it.
How can this open my mach e when there are no doors handles?
Also, looking at videos for other Ford cars, all of the keys are blanks. Does this mean you can get into any Ford car?
Thanks.
Ford Mustang Mach-E Emergency key 20240623_175531
The key is blank because it wasn't cut since you have no locks. It is cut on vehicles with locks, or locking glove boxes, or locking center consoles.
KlueBat
2022 Mach E AWD Premium, 2021 Mustang GT
The Mach E fab is the same part that is shared with many other Fords. For example the ICE Mustang as well as the F150. On those vehicles there will be an external lock cylinder on the driver's door, possibly covered by a removable panel. If you have one of those vehicles, the hidden blank will be cut to match that lock cylinder. The Mach E has no external lock cylinders, so the blank is not cut and is functionally useless.
Since you’re in the UK, I believe you can also use it to turn the switch to deactivate the passenger airbag. Of course, you could also just use a screwdriver.
phil
LS400
I use it to pry the plastic cover off the battery compartment of the key.
ack154
2023 Mach-E GT PE
Is that key Europe-specific? All of my keys (including 2 Lightning keys) separate into two pieces to reveal the physical "key". I haven't seen one like that where it's inside the fob.
It's UK specific. Fobs there are required to go to sleep to prevent relay attacks. As a result, they get a more generic Ford fob.
Brammy
paul
shropshire, uk
retired violinist
Thanks for all your answers
