Mach-E pyro fuse location
treloy
Yucaipa
2022 Mustang Mach-E
Does anyone have a diagram of the pyro fuse location on a 2022 Mustang Mach-E. Car was in an accident and starts but won’t shift out of P.
Tried finding a repair manual but couldn’t find any for the Mach-E even on alldata.
edavalos
california
mach e 2021
mechanic
Hi, did you found a solution? I’m trying to fix a salvage mach e after air bags deployed but I haven’t found a solution. I feel that I should change a pyro fuse like in other brands but I haven’t hear nothing about it on this Mach e.
There is no pyro fuse in the Mach-E. There is a large 630A traditional fuse in the HVBJB inside the battery pack. If you are repairing a vehicle that was in an accident, you need to check and address codes in all modules first. For example, you probably need to replace the RCM module and reset some things before it will start. All the high voltage systems and cables need to be inspected first. A FDRS service subscription will likely be required for this.
