Mach E Select Creak and rattle...help?
eman88
Eric
New York
2022 Mach-E GT
Tech
I was able to locate and eradicate my Mach-e rattles.
1st rattle - loose sunglasses was the culprit, I reposition (or remove) them and rattle was gone
2nd rattle - Glovebox - the small arm that connects and holds the glove box had a lot of play. I added tape around the pin the arm connects to and the rattle is gone.
Note. the Arm that connects to the pin on the glovebox is like a little shock that moves in and out, the issue is, the Arm has a lot of all-around play (which causes vibration). Ford should add a fixed guide to limit the Arm's all-around travel.
I hope this helps
Ford Mustang Mach-E Mach E Select Creak and rattle...help? GloveBox
