LOUD CREAKING Suspension issue - HELP! (Video attached)
shadowsjc
NJ
Mine is starting to make the same noise
Teslaeata
Nottingham, England, UK
Have you resolved this issue? My '21 has started to make same exact noise from rear passanger wheel area. From my experience, wheel bearings have differrent simptoms when they go bad. Was this really a bearing?
Well, I have my doubts and suspect something disturbed during the wheel bearing replacement cured the noise - dealer seems to think there’s a particular type of washer in the wheel bearing fixing station was the likely cause; replacing the wheel bearing did resolve the cause of the noise which is all that really mattered to me.
Not long after one side started emitting the noise did the other side do the same so both bearings were replaced at the same time.
Easygoing
2023 Mustang Mach-e CR1
The dealer, after I brought up the suggestion by Teslaeata, changed the wheel bearing and at the same time they replaced the rivets in the battery rail (they said the factory rivets were a little long and may be rubbing under uneven ground conditions). I've been noise free for about 2 months.
