Rattle Rattle Rattle
Carly970
Carly970
Fort Collins, CO
'23 Mach E Premium EAWD
And I know this is weak but did you check the glove box?
I removed every loose item from the car and had my 10 year old son crawl all over listening for the rattle while I drove, haha.
AKgrampy
Fairbanks, Alaska
That would drive me crazy! My Mach parks inside but I had a rattle on my Expedition that turned out to be a small piece of ice in air intake by the front wipers. It didn’t slide around but would vibrate.
Neil4Real
Do you have anything on either visor cilp? There is a clip on both sides of each visor. I had a rattle that sounded like it was coming from the dash but it was my hard plastic (I think plastic?) garage key card for the office structure, that seems to fit super snugly, rattling against he visor clip!
eman88
Eric
New York
2022 Mach-E GT
Tech
I was able to locate and eradicate my Mach-e rattles.
1st rattle - loose sunglasses was the culprit, I reposition (or remove) them and rattle was gone
2nd rattle - Glovebox - the small arm that connects and holds the glove box had a lot of play. I added tape around the pin the arm connects to and the rattle is gone.
Note. the Arm that connects to the pin on the glovebox is like a little shock that moves in and out, the issue is, the Arm has a lot of all-around play (which causes vibration). Ford should add a fixed guide to limit the Arm's all-around travel.
I hope this helps
Ford Mustang Mach-E Rattle Rattle Rattle GloveBox
