Mach-E shortcuts (please add more)
Kabish
2021 Mach-E Mustang
I use 7/8 - 9/0 all the time to lock the doors, and I can also unlock from the pillar. All the rest of the codes do absolutely nothing on my car. Would be nice to be able to unlock the frunk and trunk from the pillar, but its never worked for me... /shrug
su-ch+mache
carl
Germany
www.ford-suv-freunde.com
Escape MY17, Puma MY20, Mach E MY22 AWD ER TP2
retired buyer
just returned from my dealer, he gave me the card, on one side the EU 7 digits and aon the other the US 5 digits, am I able to use both? ?
the numbers are just to open the dorr roght? to close I just need to push the lock sign above the opening ring, correct?
markboris
Sonora, CA
Beings in the EU, you will need to use all 7 digits to unlock the doors. You can also lock the doors by push and holding the 7-8, 9-0 buttons at the same time.
tuminatr
Saint Paul,MN
2021 MME GTPE
sales
One thing I noticed when I added a third key fob is the programming process tells you the door key. You could use this process and not program a third key to reveal your door key if you're not sure what it is. Probably nice in a circumstance for someone like me who bought a used car that none of the documentation was included.
Here's a thread on adding a key fob
https://www.macheforum.com/site/threads/reprogramming-key-fob-from-another-mach-e.19031/
su-ch+mache
carl
Germany
retired buyer
it works thanks for the hint.
one question however I have left. When I open the door with the code, push the brake and the start button I need to enter a code. Which code is that?
I know I entered a code for PAAK, but it seems that's not the one I need in this case
markboris
Sonora, CA
You will only get asked to enter a backup start passcode when you do not have your car's keyfob or your phone with PAAK setup in the car. Once you set up PAAK, you can create your own start passcode.
su-ch+mache
carl
Germany
retired buyer
ok, that's what I just tried, no FOB, no phone with me.
which code is then required?
