Magneride aftermarket upgrade?
Blacklobo
USA, VA
Mach-E GT - Grabber Blue (Due 11/14)
Does anyone know if you will be able to buy magneride dampers? I have a Mach-E GT (non PE) and am happy with not buying the PE but would love to see the option to upgrade my suspension to magneride.
Not that simple, your car won't have the required wiring, ride height sensors, and the vehicle dynamic module to make it all work. These cannot be easily added and programmed without a lot of specialized technical knowledge, ripping apart wiring looms, soldering new harnesses together etc. It would be cheaper to just upgrade to the performance edition.
The retrofit question has been asked by regular Mustang owners, people will talk about it for a while but everyone gives up once they realize how complicated and expensive it would be. I can confidently say it's probably not going to happen. Just buy a GTPE if you think you want magneride since it's not something you can add later.
Blacklobo
USA, VA
Huh OK, thank you for the feedback. I thought being the same trim level it would have all the wiring in place. I guess I will scratch that off the possible upgrade list.
