Media controls for Bluetooth audio when connected to Android Auto
speed.sri
Keller TX
Premium RWD extended range
24 Mach-E RWD Extended range
First time owning a car with Android Auto(AA). Is anyone facing this issue, or know of a solution?
I usually use AA for maps and Spotify just fine. When I play any other audio from the phone when AA is connected, like audio recordings, there is no audio controls like play/pause.
When I click on the Media app my phone is there but greyed out.
When I disconnect AA I can see the controls.
Is it possible to get the controls when AA is connected?
Ford Mustang Mach-E Media controls for Bluetooth audio when connected to Android Auto Screenshot_20251212_075647_Files by Googl
Ford Mustang Mach-E Media controls for Bluetooth audio when connected to Android Auto 20251212_075700
Ford Mustang Mach-E Media controls for Bluetooth audio when connected to Android Auto 20251212_075726(1)
mdwinther35
Matt
SE Michigan
2023 Mach E Select AWD
I believe the only way to stream audio using AA is if you're using an AA supported app (eg Spotify), otherwise you need to use Bluetooth audio and the sync 4 media app.
speed.sri
Keller TX
Oh ok, thank you, upon further research, found out it's AA limitation where the Bluetooth controls API is restricted. Hopefully they will allow it.
Space_Pony
Indiana
2023 Premium Mach-E awdX
What phone do you have? I have a Samsung and use Samsung Music. Just about any media on your phone will play on Samsung Music and will be on AA. You may be able to install the Samsung Music app on other phones as well. I believe I used Poweramp previously for local media on Android Auto.
