Missing OBD PIDs for a 2025 Premium AWD SR
BOB4X
NJ
2025 Premium AWD SR, 1994 Miata
I purchased an OBDLink CX mostly to use with ABRP but have noticed that many of the expected PIDs are not available including HVB SoC. I have tried using the OBDLink app, Car Scanner, and ABRP and the HVB Soc is not available in any of them.
I added a screenshot of one of the pages in the Car Scanner dashboard. I know this setup works for others here. Any ideas on what might be causing this?
Ford Mustang Mach-E Missing OBD PIDs for a 2025 Premium AWD SR Screenshot_20250505_084508
crl
VT
2023 Mustang Mach-E Premium AWD
Try the TorquePro app? I just have a cheapo bt obd dongle and it works fine with both carscanner and torquepro.
*I did have to find and import a bunch of pids though, for tp, before it would show me much data.
BOB4X
NJ
I can certainly give TorquePro a try but these PIDs aren't coming up in 3 different apps so I am wondering if Ford changed the mapping for the 2025. How did you find pids to import? I have tried any of the profiles that make sense in Car Scanner and the one in the screenshot is the one that most people seem to use.
Ford Mustang Mach-E Missing OBD PIDs for a 2025 Premium AWD SR Screenshot_20250505_130353
JimmyMachE
Montana
Mach E
There's another profile in Car Scanner, seemingly for the latest model years. Reinstalling the app and selecting this profile might solve your issue:
Mustang Mach-E (2023-)
Justin Jeung
Justin
LA
2025 Mach e GT
Did you ever figure the issue out? I am having the same problem. The only thing i have figured out so far is that the 2025 models, ford software has a firewall blocking the info.
"For the 2025 Ford Mustang Mach-E, you can use an OBDII scanner with compatible apps like CarScanner, Torque, or specialized tools like the OBDLink CX or vLinker MC+. However, be aware that the 2025 model has an encrypted CAN bus, which may restrict access to certain data or prevent some older scanners and apps from reading encrypted values. The best approach is to use a Bluetooth or Wi-Fi OBDII adapter with a compatible app designed to work with modern vehicles or Ford-specific interfaces"
Swit3
Chicagoland
2024 CRV Hybrid, 2025 Mach e Premium
I'm having the same issue. ABRP does pull directly from AA but I keep reading the dongle is better.
